Les_Curren
Aug 29, 2013Explorer
Old-Biscuit,
Well every one is entitled to their opinion, but it would be more impressive if you were not so negitive.
To start with the two tanks you mention are actually one and it is not much larger than a couple shoe boxs You don't not need a salt tank.
All you need is salt water which is easily come by if you simply ad a little table salt to each flush. You don't need to dump your sewage tank because the residue from the Electra San is only a very small amount of powder. Maybe a table spoon or two. The rest if any is simple water. As for the extra electric load, it draws 20amps for all of a couple minutes if that long.
Perhaps you would care to mention these so called "Assoiciated problems".
Having RV issues? Connect with others who have been in your shoes.24,371 PostsLatest Activity: Mar 21, 2026
