EstorilM
Jun 14, 2019Explorer
myredracer wrote:
I'd suspect a poor connection somewhere right off the top. You *could* measure the voltage as you suggest and it may show okay but with the motor running with full load amps, a poor connection may have enough resistance to prevent the motor from running properly, it at all.
Improperly done factory crimp connections are not uncommon.
Testing with 12 volts directly at the motor or at the switch is a good diagnostic check and is probably what I'd be doing. Pulling the switch out is easy so probably a good place to start.
Okay thanks for the reply - I guess I need to get my hands on a wiring diagram for this thing, there seems to be a receiver box somewhere (guessing that's what controls extension/retraction and switching polarity for the motor?)
If I wanted to check the motor directly like you said, I can just pick a polarity and give it a shot? I don't recall if it's two wires going into the side of the TT wall, but I believe so.
Bad/loose/corroded crimp connector wouldn't surprise me one bit. :M
