em1942's avatar
em1942
Electric brake drums - how to correct out of balance
Having trouble with tires on my tandem and noticed the drums are way out of balance as they rotate rather quickly with the heavy side down when the tire is removed. There isn't any area on the drum to drill for balancing. The center hub is steel and about 6" dia x 1/2" thick that the drum is pressed onto. I could turn a steel balancing weight in a lathe and then cut/weld to the center hub but it would take a lot of weight since it would only be 3" off center. There should be an easier way to do this. Any suggestions?
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Mar 27, 2025
