lotto38's avatar
lotto38
Electric Brake Issues on TT
I have a wheel on my TT that seems to be getting more "Juice" than the other three. I have my prodigy gain set at 6 and the boost at 1.(Same problem if no boost) In a short drive, the wheel will heat up more than the other three.It sometimes gets hot to the touch. I jacked it up and the wheel spins without any resistance. I have had two shops look at the wheel and they both say everything is OK. I am wondering if they check the voltage in each wheel. I don't believe that the Prodigy is to blame, because there is only one wire going to the plug. On gravel with the boost, the wheel will lock up.
Thanks.
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 07, 2025
