John___Angela
Nov 12, 2016Explorer
Electric vehicle EVSE install in RV. Pics.
Hi all. For those with or getting EV's here is our install in our basement cabinet of our motorhome. It is on a hung bracket available with the unit...eg...it can be moved from your garage wall to the motorhome in a matter of minutes or just put it in the car for portable use. It is a 40 amp 10 KW unit with wifi control so you can control the output based on what the supply voltage and current is. Totally controllable from a smart phone. Comes with a standard 50 amp 220 RV plug. Can be bought with all the adapters to adapt to 220 30 amp dryer, 110 30 amp RV plug and 15/20 and 110 standard plug. Compatible with all electric vehicles. We haven;t had it long enough yet to know all the ins and outs but seems to do what it is supposed to do. Our present EV has a smaller 3.3 KW level 2 charger, but we are buying a second EV to replace our last oil burner in the next year and it will have a minimum 6.6 KW charger.
Cheers.
Cheers.
