Electric
ldhart1959
Electric outlets work when generator is on but stop as soon as generator turned off. The battery is switched on. Any suggestions?
3 ACCEPTED SOLUTIONS
opnspaces
Navigator II
Navigator II
Agreeing with QCMan, we need a bit more info.
But generally as he said your electric outlets and air conditioner are 120 v AC and will only work when plugged in to shore power or with a generator. The rest of the coach (lights, water pump, furnace etc) is 12v DC Battery powered.
Plugging in to shore power will start to recharge your batteries.
View solution in original post
Grit_dog
Navigator
Navigator
I’ll guess. You don’t have an inverter, so the AC receptacles should not work when unplugged from shore power or genny turned off.
Thanks. Very helpful. Our first camper - still have lots to learn.
8 REPLIES 8
ewarnerusa
Some good reading to introduce you to the 2 different electrical systems in your camper.
12 Volt side of life part 1
12 Volt side of life part 2
Aspen Trail 2710BH | 470 watts of solar | 2x 6V GC batteries | 100% LED lighting | 1500W PSW inverter | MicroAir on air con | Yamaha 2400 gen
way2roll
Navigator
Navigator
Newbie hit and run post.
pianotuna
Nomad II
Nomad II
The outlets are not 12 volt powered. One would need to add an inverter to have power without the generator or shore power.
Regards, Don
valhalla360
Nomad III
Nomad III
A bit over simplified.....
Electricity comes in two flavors:
 - AC: Alternating Current: This is the power you have in your house and the outlets that look like the ones in your house. It's generally runs around 120 volts but 60 times per second, it reverses direction. Usually, you get AC from plugging the RV into a shore power pedestal or your generator puts out AC.
 - DC: Direct Current: This is what your batteries put out when you call on them. It generally runs around 12 volts and stays in the same direction. Your car starter for example runs on DC.
There are devices in your RV that run on AC and those that run on DC.
 - All RVs have a battery charger (aka: Converter). This takes AC and converts it into DC for direct use and to recharge the battery.
 - A small percentage of  RVs have an inverter. This takes DC and coverts it to AC, so that you can use AC while disconnected from an AC source. Of course, it uses up the battery power, so it's limited in what it can run and for how long.
My bet is you don't have an inverter, so when you shut down the generator and are not plugged in, there is no source for AC power and thus your outlets don't work.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Grit_dog
Navigator
Navigator
opnspaces
Navigator II
Navigator II
QCMan
Nomad III
Nomad III
You do not give enough details to give a proper answer to you but generally the outlets only work when there is input to the trailer from the generator or shore power. You do not state if you have a battery bank and inverter so the above is the best answer to your question with the info given.
2020 Keystone Cougar 22RBS, Ram 1500, two Jacks and plenty of time to roam!
The difference between genius and stupidity is that genius has its limits. A.E.
Good Sam Life Member
