MEXICOWANDERER
Jul 11, 2015Explorer
Good post Landy. Some folks will shriek at the cost of the CAIG products then continue to lose ten percent fuel mileage or equipment that does not work right. I proofed it on a NEW OUT OF THE BOX Alfa wi-fi booster. Two bars signal strength. The laptop already had a treated USB port.so the antenna, adapter, and amplified USB cord got treated. Five bars signal strength. Used it on my toad temperature sender on the engine. Immediate climb by two needle widths. Instead of displaying cold on a warm day it reads correctly. The stuff is amazing.
BTW kudos on your figuring out the emissions test is danged sensitive. The interconnection of all systems to the ECU is the key to good fuel mileage. I am driving a toad that registers the first 25% on CO NOX & HC. Not bad for it's 25th birthday.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 16, 2026
