sjturbo
Oct 18, 2014Explorer
Electrical Problem. Please advise.
I will try to make this short. The high/low fan function on my Coleman air conditioner does not work. Could this be the reason?:
I recently installed a Power Bright inverter to a circuit in my 5er. I did this by removing the hot, neutral and ground from a circuit breaker on the circuit breaker panel and tying it directly to the hot, neutral, and ground on the extension cord, (12ga) that I then plugged into the inverter. I know that the fan worked originally but not sure it worked recently because I had not used it lately. I have checked voltages on the Coleman control box and it appears that I have AC voltage coming in but not going out of the circuit board. I don't want to replace the control box only to damage it again. Could my wiring of the inverter have caused a short circuit somehow?
