My 30 amp trailer wont handle all my appliances. Want to run a wire with male plug from the out door post to a receptacle inside the trailer.( to be installed) What type of wire should I use? Thanks
Do you run all the appliances at the same time? We also have 30 amp and are careful not to run two appliances that heat up eg. frypan and toaster oven. Other than that we don't really have a problem.
