asherl33ExplorerApr 21, 2014ElectricalMy 30 amp trailer wont handle all my appliances. Want to run a wire with male plug from the out door post to a receptacle inside the trailer.( to be installed) What type of wire should I use? Thanks
RoyBExplorer IIApr 21, 2014I just ran a 25-foot HD yellow extension cord out thru the pass-thru area and plugged into the pedestal 20AMP service. 12-3 I think it is...Then I plug both my oil-filled portable electric heaters into it. I never run my heaters full blast - usually set it between 3-4 on one heat zone.Roy Ken
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,191 PostsLatest Activity: Jan 19, 2025
Related ContentElectricElectrical assistanceElectrical outlet issueselectricalSurge or electric brakes
