4x4van
Dec 11, 2020Explorer III
way2roll wrote:
Not just hearsay, I've heard of real cases of things getting screwed up when running the genny and shore power at the same time.
Ummmmm....isn't that the very definition of "heresay"?;)
Seriously, there is no need to disconnect, but it is a good idea to shut down any heavy loads (A/C, WH, etc) prior to firing up the generator. If the transfer switch works, it will simply switch over to generator power (after a short delay for warm up/rpm settling). If it doesn't, it will remain on shore power. There really is very little possibility for it to connect to both at the same time. The contacts can only be in one position at a time; it is a "break, then make" system.
