joelyn's avatar
joelyn
FanTastic bathroom fan?? ((UPDATE)){{{UPDATE}}}}
Have a bathroom fanTastic fan which has a 12v motor on it like this...
Fan Tastic Fan
I replaced the motor lift assembly about 3 months ago and fan worked fine opening and closing cover after flipping the switch... about 2 weeks ago I went to open the vent and the motor turned the knob about 3 turns and the vent opened about a inch or so and stopped. I had to turn the knob manually to open vent and have fan turn on. when I flipped the switch to close it nothing happened. Had to be closed manually... Same thing happens every time I go to use the fan...
I have 12 volts to the motor and thats about all I checked. Any suggestions as to what else could be wrong or what to check for?? I don't see any obstructions or anything in the way. The trailer is in the same location when the motor worked and when it stopped.
Thanks for any help.
