dpgllg's avatar
dpgllg
finishing installing Battery Disconnect and power inverter
My 2017 Grand Design draws power to Co2 detector and Slide 2 even when battery disconnect is turned off. The slide when in blocks the back of 5th wheel and the dealer said this is a safety device.
Well I'm going to install a battery disconnect that will kill everything when off and also a small power inverter.
My question is will the power inverter draw power from the battery when the inverter is not being used? I went online and some say yes others no so I'm really not sure.
What I would like is to connect the inverter to the disconnect switch and when power is on BUT I'm not actually using the inverter it will not draw from battery.
There is a power switch on inverter and I would keep this at off until I wanted to use inverter.
Thanks!
Dave
