pianotuna wrote:
Hi,
And what was the specific gravity of this fully charged battery? Or resting voltage? (i.e. sitting for 24 hours with no charging and no loads?)
dddire wrote:
pianotuna wrote:
Hi,
Unless you have beefed up the charging path, very little will be sent to the "house" battery bank from the alternator. Think BIG fat wire (#4?).
With a small battery bank it is better to do closer to 150 watts of panels for each 100 amp-hours of storage. With that small a bank, Keurig is going to be a gen set run.
We have run the gp24 down to about half a couple times, then by the time we've got home, it's full. When the brake control/7 pin was put in, I mentioned I wanted the ability to makre sure it charged the house battery and the tech response was "nothing to worry about"... and I guess I never really thought about it after that. lol
hahahah.. .what you mean the little 4 dummy lights on the TT control panel are not accurate Tuna?
No idea good Sir. I'll take a volt reading before I slam the battery this week with the coffee maker and get back to you with before and after readings. I'll pick up a hydrometer as well. ;)
