mikemc53's avatar
mikemc53
May 24, 2021
Fresh Water Drain
Just purchased a 2021 Gulf Stream Class C Conquest 6250D. Does anyone know if there is a specific drain for the fresh water tank or do I need to just run it dry with the pump? My Class A has a large valve that will drain the tank itself but I have been unable to find one on this. It has low point drains but they likely will only drain what is in the lines and then I would need to run the pump anyway - wouldn't I? It was winterized at the factory and now I need to clear the tank and the lines.
Thanks gang.
  • Just purchased a 2021 Gulf Stream Class C Conquest 6250D. Does anyone know if there is a specific drain for the fresh water tank or do I need to just run it dry with the pump? My Class A has a large valve that will drain the tank itself but I have been unable to find one on this. It has low point drains but they likely will only drain what is in the lines and then I would need to run the pump anyway - wouldn't I? It was winterized at the factory and now I need to clear the tank and the lines.
    My 1990 Winnebago Warrior has 4 low-point drains. If you open them all and open your faucets the entire system will drain, tanks, lines, and all. No need to run the pump.
  • madjack60 wrote:
    Also, there should be a manual with the unit and it will tell you all you need to know
    that's not true. most RV manufacturers only provide a generic owners manual, with no model-specific information.
  • Ours has a tap at the back corner on the driver's side. (Not your make or model). If you can see the tank, look for a line coming out of it other than to the pump. trace this.
  • Go underneath your new C with eye protection and a flashlight. You’ll find it.
  • Also, there should be a manual with the unit and it will tell you all you need to know
  • Some will be under the bed if it is storage underneath, some are in the compartment for the storage. You can Google that question for your model and there may be a YouTube video for it
  • jdc1 wrote:
    That's one thing that should have been disclosed during your walk-through.
    WOW that was helpful :S smh
  • jdc1's avatar
    jdc1
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
