Hankjoe
Oct 18, 2017Explorer
Fresh Water problems are they related, help!
The water pump was noisy (didn't want to shut off after turned on faucet) - yes there was water in the water tank. Then it wouldn't pump
A. We unhooked the line to the tank & put the line from the pump into a pail of water and the water pump worked fine to include - shutting off when the pipes were full of water.
b. We unhooKed the line from the tank & no water came out even with a full tank. We blew air back through the line & heard bubbles, but water didn't flow back out the line What do we do next??
Second problem (related or unrelated) When we pull the gavity flow drain plug no water is released from the tank.
We have a Class C Shasta Motor home. The water pump is pull for drain is under the dining bench. The Fresh Water tank is under the other dining bench seat.
Ideas of what to do next? Thanks
