fridge level?
coolmom42
I searched and didn't find an answer...
My Class C is parked in my yard, waiting for the concrete guy to pour a pad. It's level front to back, but about 3 degree slope side to side of the RV. This means that the refrigerator is level left to right, as you stand looking at it, and off from front to back. I know the coil basically zig zags left to right, but it won't be vertically plumb.
Is it OK to run the fridge in this situation? I just need to cool it down before a trip.
Single empty-nester in Middle TN, sometimes with a friend or grandchild on board
14 REPLIES 14
Lynnmor
kellem wrote:
Was always under the impression that front to back leveling was more critical as long as left to right wasn't extreme.
If you read your manual you might get a different impression.
kellem
Where are trailer parks all winter with frig running 24/7 is level front to back but trailer leans down slightly towards frig....no issues.
Old-Biscuit
coolmom42 wrote:
Old-Biscuit wrote:
Open fridge outside compartment
Look at the absorber tube bundle....large slanted tubes
Are they running downhill....OK
Are they level....no downward slope ----NOPE
Are they running uphill .....NOPE
Can you clarify on the uphill/downhill? Which side should be lower, as a person faces the outside compartment?
Absorber tubes slant downward to help gravity flow
If when parked those tubes are NOT slanted downward then gravity flow will be disrupted
See how they are slanted downward
coolmom42
Thanks for the replies. Temps will be in low 40s when I leave, so it won't take long for the fridge to cool down. A cooler will work for a few hours.
I'm not wanting to do a lot of moving the RV in the yard since it's very wet. My concrete guy supposedly has me on the list in the next 3-4 weeks. Hoping the weather cooperates and the pad gets poured before long.
ajriding
Don't do it.
As above, 3 degrees side to side (the fridge) and 6 front to back is max. You said about 3. If it is less than 3 side to side then might be ok, if more then will be bad.
What happens is the liquid will get trapped in the coils when it is off-level and because it does not drip back down into the boiler section and keep it full damage will occur.
A little bit of liquid trapped may or may not be a problem, but do you want to take that $1,500 risk?
I have friend that swears that his fridge can run off-level and he never bothers to level the camper for the fridge. Now he does not know why the fridge will not work.
This process of damage takes time. Damage builds up until eventually, usually on a hotter day, it just will not work.
otrfun
Typically, you're supposed to operate a fridge not more than 3 degrees off-level, left to right (looking at the front of the fridge), and not more than 6 degrees off-level, back to front. However, operating a fridge at or slightly below its max off-level spec is no guarantee it still won't suffer some slow, cumulative damage. Been there, done that. The only way to be absolutely sure your fridge is operating safely is by monitoring the flue temps. We take the stress out of off-level situations by monitoring our flue temps with an ARP Fridge Defend.
coolmom42
bukhrn
Not sure i've ever been Exactly level, never had a problem ,if I get it somewhere in The bubble, close enough.
2007 Forester 2941DS
2014 Ford Focus
Zamboni, Long Haired Mini Dachshund
Old-Biscuit
midnightsadie
I use a bubble level on the countertop if its inside the bubble? I use it ,never had a frig problem and its 12years old.
Bill_Satellite
pianotuna wrote:
I'd do a bit of leveling.
X2. As mentioned above, a couple of boards should get you less than 2 degrees which is recommended.
Can't we all just get along?
pianotuna
Nomad III
Nomad III
Regards, Don
MFL
Nomad II
Nomad II
If sure of degree out of level, probably okay. but it can't be too hard to just put a couple boards down on the low side, to remove any concern. It should be easy to move a C ahead/back a little, if in running condition to take a trip soon.
Jerry
Lwiddis
Up to three degrees side to side and up to six degrees front to back is fine with newer Norcold RV fridges.
