StewB's avatar
StewB
Fridge on its side?
I am going to pick a RV fridge up on an upcoming trip. It won't fit under the canopy on my trick so I will have to lay it on its side. It would be like this for a day or two.
Any problem transporting a RV fridge like this?
  • You really don't need to wait- you can hear the liquid flowing. As soon as it stops, you're good to go.
  • westend wrote:
    Just make sure it has been upright and agitated a bit before installing and using. I would allow a couple of days upright between shipping and installation, rocking it gently and occasionally raising the bottom sides to allow any entrapped fluids to seek their proper location, i.e. refrigerant to flow back down to the bottom.
    YEP^^^^^
    Lay on 'boiler/stack' side and then upright for at least 12 hrs titling each corner for few minutes
    Ammonia solution needs to settled DOWN and Hydrogen Gas needs to flow UP
  • Just make sure it has been upright and agitated a bit before installing and using. I would allow a couple of days upright between shipping and installation, rocking it gently and occasionally raising the bottom sides to allow any entrapped fluids to seek their proper location, i.e. refrigerant to flow back down to the bottom.
Having RV issues? Connect with others who have been in your shoes.24,211 PostsLatest Activity: Mar 11, 2025
