Drew_A_'s avatar
Drew_A_
Fridge runs warm when temperature climbs into high 80s
Greetings,
We have a brand new 2021 Imagine 22MLE with a Dometic 2882 installed in a slide. The fridge has been running in the high 30s with the temperature control on "3". (This unit has temperature control 1-5, so "3" is in the middle."
Just recently we had temperatures climb into the high 80s and we were camping in direct sun without shade. I heard the condenser side fan turn on, but the fridge temps climbed into the low 40s. The freezer runs around 0 to a few below.
I'm wondering if an internal fan on the evaporator fins will help. I will be checking the condenser side fan and see if more airflow there is needed.
Any experience with the internal fans helping or is increasing the condenser side airflow more important.
Thanks, Drew
Having RV issues? Connect with others who have been in your shoes.24,200 PostsLatest Activity: Feb 18, 2025
