DutchmenSport
Sep 01, 2019Explorer
Was the front air conditioner running when you the "BS" walk through?
Not to undermine your intelligence or anything, but did you flip the breaker switch at the power panel for the air conditioner? I have found on my 5er, there is one breaker that sometimes, somehow, flipps to off when traveling. All I have to do is flip it off and back on again. This happened twice over the last year, same breaker.
I'm assuming your front air conditioner is an air conditioner and heat-pump combined. If yours is a digital thermostat where you push buttons, it's possible you may be in "auto" mode and it's neither hot or cold enough to activate. Also, there is a delay with hose electronic thermostats. Sometimes, it takes 30 - 45 seconds when flipping on the air or the heat pump before it starts running. Just saying, have you been patient enough and waited after flipping it on?
Let us know what happens.
Having RV issues? Connect with others who have been in your shoes.24,366 PostsLatest Activity: Mar 09, 2026
Related Content
- Feb 01, 2026Community Alumni
