DanMar's avatar
DanMar
Front slide not working
Hello Folks, just bought a 2000 Holiday Rambler Endeavor with two slides on same side..Freightliner chassis...my problem is the front slide switch (over the passenger seat) does not work on occasion. I can hear a clicking sound underneath in the middle of the chassis, but the gear won't engage. This has happened a couple of times, so it works intermittently. I've checked the fuses/breaker but can't find the source to correct the issue. Any other H/R Endeavor owners having/had same problem..your help is requested..Thanking you in advance..Dan B.
No RepliesBe the first to reply
