- dave61ExplorerThanks for the info Fourthclass. I found that the gap was between the window glass piece itself and the sealing surface of the front cap. I sealed it up using a non-hardening caulking cord and then blasted it with a hose to leak test. So far it seems to have fixed the issue. Coachmen recommends having an automotive glass service come out to remove and then reset the window with new adhesive. That might be next if the problem resurfaces.
- fourthclassCExplorerHad a separation between front fiberglass cap and the front wall above the window. 02 winnebago mini. Even found a small dead bird in there. It was a big gap. In my case the wood screws that held it on (wood backing cast into the backside of the fiberglass) . I will go back with coarse thread wood screws and re caulk with Proflex. I suspect you had a similar separation.
Having RV issues? Connect with others who have been in your shoes.24,216 PostsLatest Activity: Mar 15, 2025
