mrmatthew's avatar
mrmatthew
fuel
1985 Chevy 454 external fuel pump 7 to 10 pounds psi after sitting for 30 minutes fuel cannot be sucked out of a tank to brand new fuel pumps I'm stopped I am a mobile mechanic in myself what do I do it seems like it needs to be burpedif I take off fuel line going to engine directly from fuel pump its ok but sitting after 30 minutes it will not suck up out of the tank
  • Matthew,
    Have you tried opening the fuel tank cap?
    This is an issue that is not uncommon with that period GM vehicles. There was a problem with the purge canister valving.
    Note, If you include some breaks and punctuation, it makes it much easier to read. Even if you are working form a small device, breaks alone can help to separate the thoughts.
    Matt
  • Sounds like a tank venting problem. See if everything works with the gas cap removed. If so replace the cap.
  • j-d's avatar
    j-d
    I'm thinking "sock" too, and wondering if there's a plugged vent creating vacuum in the tank. I'm familiar with FORD's of that era. They had in-tank electric pumps that worked on the "Archimedes Screw" principle. That design would allow an external pump to pull fuel through. When Ford went to fuel injection, the pumps changed to a Vane-Type and a failed pump had to be replaced. Or removed and replaced with tubing to use an external pump.
    Also, many OP's here with external pumps on Ford's have found they don't last all that long. Again, you're working on a Chevy so I don't know how much of this applies, but I hope it helps.
  • It might be the mylar sock (filter) on the suction pipe in the rule tank is becoming clogged after it sits for awhile the debris float away and the pump will work again. Might have to pull the tank and clean it out
  • My 454 has a pressure regulator on the frame near the fuel tank.
    You can see a picture HERE.
    Could there be a problem going on in this part?
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 23, 2026
