allersj wrote:
Thank you all once again for the suggestions. The one that I am definitely going to check out is the air leak theory especially around the slideouts. It never occurred to me that that could be the issue. I do remember that around June of last year I had to adjust my one slideout. The top was sealed up tight, but the one bottom corner (about 3 feet from the furnace return), had a sizable gap. I did get it adjusted so that it closed up. But I'm sure it was like that from when I opened the camper up in the spring. If the furnace was just constantly sucking in cold air those nights, I would bet that would make it use quite a bit of gas.
Hi,
I'll throw my experience into the mix as we have winter camped a fair amount, and I have an above the average RV'er understanding of the Atwood hydroflame furnace. At least I think anyway.
What is the brand and model of your furnace? It can help give better answers to your exact furnace, but the Suburban works very similar in the big picture to the Atwood.
Some comments that may help spark some ideas for you to check.
Doug R gave a lot of good facts on the furnace system. I'll add a few extra. You stated the furnace system used to work correct in your mind, and now it appears to be burning through a lot of propane, what changed? In the furnace there are 2 areas that I will explain to help you think, maybe it is OR is not the furnace?
A. In the furnace, there is a gas jet at the end of the gas valve, that jet orifice is precision machined to deliver a certain BTU rating at a certain gas pressure (11" WC pressure). The only way to get more gas through that same size hole is, the hole got bigger or the gas pressure was higher. Flow is proportional to the pressure drop across the orifce.
B. The furnace has a high temp limit safety switch. If that high temp switch is tripped, it shuts off the gas valve until the switch and furnace cool down to it's differential setting, and then the gas valve opens back up. You can hear the burner cycle, the fan keeps running, the burner goes on an off. If the system is ducted and sized correctly (many campers are not) that switch should never trip as the air flow over the heat exchanger inside the camper should be cooled enough to not over heat. And if the gas side of the heater exchanger is blocked, the gas fumes can't get out and that too will cause the high limit to trip.
Now understanding those two areas of the furnace, gas orifice jets do not wear out very fast, if ever. It takes a boat load of time and flow to erode the jet. What are the odds the jet got bigger from when the camper used to work until now? Slim I think, but ask your self that. If the jet did not change, then the LP burn per minute did not increase. So you can rule in or out the jet, I think anyway.
The main tank LP regulator is supposed to limit the gas pressure when the furnace is running. Doug can confirm this, but if the main tank regulator went up to 14" WC when the furnace was running, that is the max limit considered OK for a wide open main tank regulator. The 3" WC extra pressure could increase the LP gas flow through the same size orifice, (~ 28%) but the main tank regulator could of been doing that when the furnace worked when you thought it was working right.
If the furnace was using more LP for increased LP pressure, it would create more heat. The BTU's are being burned, the heat is coming out of the furnace. BUT there is the high limit safety switch that will shut down the gas valve if the heat exchanger gets too hot. With that high limit in the mix, how can the furnace create excess LP usage as the limit switch keeps shutting down the gas valve? You can hear the gas valve going on and off by the roaring burner sound of a 30K or 35K furnace without much trouble.
Think through the above, it can rule in and out the furnace is your issue. From what little we know about your furnace, odds are, the furnace is not burning more LP gas then it used to a year or so ago. You are loosing heat out of the camper or taking in more cold air.
You said you checked all the fittings for leaks and found none, well the fittings may not be leaking, the gas valves and gas regulators can, but still those leaks can be small, and it's hard to leak a good part of a 30# tank in 7 hours and not smell it. The water heater, the furnace, the fridge, the stove, the main tank and stove regulator can all leak, but again, you did not smell it. The stove is inside, that you can smell more easy, the rest of those valves/regulator are outside or closer to outside.
If you want to rule out the LP gas system itself, educate your self on these 3 LP gas checks. These are standard LP system gas checks. You need a manometer or a gas gauge to do them.
1. A system pressure drop test
2. A main regulator pressure set point test
3. A main regulator lock up or max pressure test
Those 3 tests will confirm you have "no" leaks in any of the LP system, it will confirm the main tank regulator is not passing very high pressure and if the main tank regulator is not too low in pressure. In your case, low LP pressure is not what you are seeing, but it's good to know so all LP systems are working right.
Once you rule out the furnace itself, you come down to, heat is escaping the camper, or too much cold air is entering the camper.
No one yet asked if the wind was blowing outside? Was it?
No one asked yet, do you have single pane glass windows?
You said you used to use an electric heater and that would keep the camper warm. A 35,000 BTU gas furnace can create a lot of heat if you actually burned a 30# tank over night, where did all that heat go?
How many electric heaters did you have? 1 heater, 5 heaters? Are they 1,500 watt heaters? If your camper is 30 amp service you only have so much power. If your on 50 amp, the wall outlets are still limited, you can only plug in so many heaters and not trip out the 15 amp circuit breakers. You need a lot of electric heat to create the amount of heat a 30# or 20# LP tank (if the tank was not full) can give you.
This comes back to, I think more cold air came into the camper, and or you lost more heat from the camper, or both, through ducts blowing in the wrong place, etc.
This much I can tell you from our winter camping. Single pane glass sucks for heat retention. The windows would be totally covered in wet condensation. Was yours?
Slide rooms, the rubber seals stink for heat retention and can allow cold air in. The slide floor is many times not insulated. You have 3 slide? We only have 1 slide on our 32 ft camper with a 35,000 BTU furnace. You have a lot more heat loss in the just slides.
If the wind is blowing, all the window leaks and slide leaks can overpower the furnace. We went to the shrink wrap on the windows for the single pane glass and that made a large difference in heat loss and cold air entry and dropped the wet windows to almost nothing. We also have to deal with all the humidity in the camper. We crack open one roof vent a good 1" up,(yes it lets heat out) we run a dehumidifier, we set the T stat at 64F at night, we run one oil electric heater and one ceramic heater powered by a separate 120 VAC power line into the camper (we only have 30amp hook up), we practice extra venting of the camper when we shower and when we use the range top for cooking to let out all that excess moisture. And I added 4, attic vents in the roof to let the excess moisture out of the attic to not all mold up the attic. Yes, the attic will mold up if you camp a lot in times of high internal humidity and do not deal with it to keep it in check. We camp down to 30F often, days are only about 45 to 50F but the sun helps heat the camper during the day.
We have an enclosed tank compartment and 2 heat hoses goes through that compartment to convect heat into the area of the tanks. I added extra insulation in the tank compartment to not loose excess heat. I also have a temp sensor in the tank compartment to know what the temp is. We have to have the furnace on to keep the tank compartment warm enough to not freeze a tank. All my dump valves in inside the tank compartment.
If you read all this this far down, what makes more sense to you? It points to, you lost more heat then usual and or, you took on more cold air, or both.
Hope this helps, and report back your findings. We all learn something from this.
John
2005 Ford F350 Super Duty, 4x4; 6.8L V10 with 4.10 RA, 21,000 GCWR, 11,000 GVWR, upgraded 2 1/2" Towbeast Receiver. Hitched with a 1,700# Reese HP WD, HP Dual Cam to a 2004 Sunline Solaris T310R travel trailer.
