Skidus1
Jun 27, 2018Explorer
Generator adjustment
I got my old 3500 watt Coleman gen out to run it a bit and checked the voltages. I only use it to run ac or make coffee. I adjusted the Hz to 60 under the ac load and I have 117 volts on the gen outlet and 109-110 on the inside trailer outlets. When I turn the ac off the voltage on the gen goes to 133 and hz to 63.8. Question is should I adjust hz under load or no load. I did it under load. The hz dropped to around 57 after ac was turned on when I set it to 60 hz. Thanks
