hud60
Sep 20, 2020Explorer
generator question
does anyone know if I can pair a 2021 onan gen. prepped 5th wheel with a Honda 6500 generator? could a knowlable electrician be able to do this?
does anyone know if I can pair a 2021 onan gen. prepped 5th wheel with a Honda 6500 generator? could a knowledgeable electrician be able to do this?
ajriding wrote:Beats me. The story changes.
you are wanting to pair to make 240 volts?.
rlw999 wrote:wnjj wrote:rlw999 wrote:
I don't see any ready-made 50A bonding plugs, so this is probably something to talk to an electrician about.
You can bond anywhere there is neutral and ground available on the generator, for example the 120V receptacle.
I didn't want to suggest that (even though it will seem to work just fine), because then you're bonding a 50A circuit over a 15/20A path.
