โDec-31-2018 06:52 AM
โJan-02-2019 11:31 AM
LittleBill wrote:
what is the breaker rating? it appears 20 amp on HD website.
โJan-01-2019 10:20 PM
LScamper wrote:
wa8xym
"IT ALSO ADDS A VERY SMALL LOAD yes. a cord even with nothing plugged in presents a very tiny load to the generator."
Please explain, I don't understand this. (Small capacitive load? Small reflection from an open circuit depending on cord length?)
โJan-01-2019 01:02 PM
โJan-01-2019 12:32 PM
Gdetrailer wrote:pnichols wrote:Gdetrailer wrote:
Acutally 69DB is LESS than any builtin RV gen like Onans and a heck of a lot less cost..
Hmmm ... I wonder where this came from?
Click around on this website until to get to a common RV Onan generator's specs like their RV QG 4000 model: https://www.cummins.com/generators/rv-qg-4000
Here's a clip out of the .pdf specification for their 4000 watt model from the above website:
"Sound: 68 dB(A) readings at 10 ft (3 m) half load
* Meets National Park Service sound level requirements
(60 dB(A) @ 50 ft) for use in national parks.
* Typical installation will further reduce sound level."
The last sentence is important. Since the noise spec is for the "naked" Onan generator sitting there in only it's included case ... when it's well mounted and additionally enclosed inside an RV's outside cabinet (but open at the bottom for air flow) the actual noise heard by others outside the RV in most camping situations should be very bearable when within generator hours.
Our built-in 4000 watt Onan's sound seems nicely muffled (well below 60 dB(A)) from 50 ft away outside the RV - just a steady 3600 RPM low hum regardless of the load it's delivering. Winnebago sound-isolated it's noise output such that when inside the coach - with respect to the camping independence it's providing - we can easily tolerate it's humming. We have even run it nearly all night for A/C while we were drycamp sleeping in hot and humid conditions.
Obviously, YOU have NEVER had to SLEEP beside a motorhome RUNNING an Onan..
I CAN easily HEAR a Onan running in a busy Walmart parking lot well over 100 car spaces away (1000 ft at 10ft spaces) INSIDE MY RV.
I would rather listen to a Refrigeration ("reefer") truck parked next to me..
YOU might "think" your "built in" is quiet, but your neighbors may not have the same opinion.
โJan-01-2019 11:36 AM
โJan-01-2019 10:47 AM
LittleBill wrote:95jersey wrote:Gdetrailer wrote:95jersey wrote:
So just to be clear, the limit is the 13.3 amp per outlet, so moving to even 6500/5500 will be the same issue as the outlet does not exceed 13.3 amp? If this is the case why do they even sell these at higher wattage ratings...confused!?!
If I get the 6500/5500 unit would I get 2750 (5500/2)? That may be all I need, and it is 1/2 the price of the inverter.
5500W gen will get you 2750W or 22.9A on EACH of the Duplex outlets which IS still going to be the SAME ISSUE YOU ALREADY HAVE WITH YOUR CURRENT GEN.
A 13.5K BTU A/C is going to draw a min of 12A (1440W) when RUNNING, however the START UP SURGE of the compressor can easily exceed 20A when HOT. Add in any other loads and you are bound to come up short and having random gen breaker trips.
Something else to take into consideration is the AVR (automatic voltage regulator) which samples ONLY ONE of the 120V windings.. Plug into the side which is not sampled and you will have larger voltage swings..
So far by being cheap it IS costing you a lot of money in randomly buying undersized and wrongly wire gens.
Your HF 3200W gen right now is $339 and a 5500W gen is $489 for a grand total of $828 plus tax you have potentially wasted..
Sure, you CAN try to sell that 3200W HF gen, but, you ARE going to have a difficult time selling it AND you are going to have one heck of a time getting even $150 out of it..
People who buy used, buy it for CHEAP.
Put it another way, I HAD a 2000W Chinese built gen which I paid on sale for $175, it was too small for my camping, only had 120V so wouldn't help for home backup. I ran it for less than 5 hrs and it sat in my garage for 5 yrs unused..
I decided to sell it, placed ad on Craigslist for $125, months go by and not one call..
Sat it at the curb with for sale sign for several weeks, fellow stopped by and we agreed on $75..
Do yourself a huge favor, just go buy the HF inverter gen and be done with it..
If you not willing to spend for tan inverter gen you WILL need to look elsewhere for a gen which is 120V ONLY..
I have a Buffalo Tools 4Kw gen which is 120V ONLY that I use for my camping.. Not sure if they sell under that name anymore, seems to me they changed to "Sportsman" brand..
Looks like this..
Found that pix HERE but they are out of stock.. Too bad, cost is $293
There ARE other "brands" of the Chinese clone gens that are 120V only in non inverter setup, you simply NEED to do some detective work.
READ the information carefully, if it says 240/120 you NEED to stay clear of that one.
If it says 120V ONLY then you have a winner..
Just be aware, many of these Chinese Clones have very little warranty/parts support (same with HF, they don't carry or sell repair parts). You will be on your own if it breaks.
Thank you for this recommendation, found it for $229...awesome!
considering there are 2 ac breakers on that unit, he's pretty much going to be in the same boat as the generator he has now.
he needs a generator with a 30amp 120v outlet on it, to get full power from both windings. it has nothing to do with what voltage its putting out. No genny manufacture is going to put bigger then a 20 amp breaker on a nema15r
โJan-01-2019 10:42 AM
โDec-31-2018 08:53 PM
pnichols wrote:Boomerweps wrote:
To give you an idea of your power usage to compare to available amperage, here's my measurements on my TT:
Fridge 328 watts 2.733 amps
Bathroom fan 40 watts 0.333 amps
Microwave 1230 watts 12.05 amps
AC 1446 watts 12.05 amps
D.C. Inverter at idle batteries charged 14watts 0.117 amps
Water heater 1245 watts 10.38 amps
Toaster 692 watts 5.77 amps
Electric space heater 1500 watts 12.5 amps
Electric griddle 1500 watts 12.5 amps
Single serve coffee maker 800 watts 6.67 amps
Add 'em up, read 'em and weep, but don't go over 30 amps!
Because of the above, I added an extra stand alone receptacle with its own power inlet on my TT. I also run an extension cord separate from the power source to a table under my awning for cooking gear and such. Also I shut off my air conditioner when using the microwave. Those two with the converter (amp draw depending on battery charge status) and fridge and anything else using electricity could put me over 30 amps. Heating elements are always a large draw. Water heater, space heater, cooking elements.
Since we're talking about generators, I guess that means that we're talking about drycamping.
So ....:
1. What combinations of the items on your list do you really have to run at the same time?
AND
2. What is the impact of propane on electrical power usage with regards to your list?
Our 4000 watt built-in generator and propane supply can handle just about any really necessary simultaneous combination from the list.
โDec-31-2018 08:26 PM
โDec-31-2018 07:56 PM
โDec-31-2018 07:22 PM
โDec-31-2018 07:17 PM
Looks like this..
โDec-31-2018 06:52 PM
Looks like this..
โDec-31-2018 06:27 PM
