korbe
Oct 19, 2014Explorer
After I drain the water heater and with the plug still out, I pump the pink stuff toward the tank just for a second or two to fill the short section of line at the tank. I will then switch the bypass valve and I am done with the tank except I will place the drain plug back in a couple of turns to keep out things. I also tie a bit of red flagging on the exterior tank access door to remind me that the plug is not tight.
Having RV issues? Connect with others who have been in your shoes.24,192 PostsLatest Activity: Jan 26, 2025
