AndyfromTucson's avatar
Nov 02, 2016
Great Stuff expanding foam adhesion test
TL;DR: Expanding foam can be an excellent adhesive for delamination repairs if it is clamped.
As described in some of my other recent posts, I am in the middle of repairing a large delaminated area on my Class C cabover. I had seen a number of people mention using expanding foam as an adhesive for delamination repairs, so I decided to do a test piece using Dow Great Stuff Windows & Doors expanding foam, styrofoam (EPS), luan, and FRP paneling (orange peel surfaced stuff sold at Home Depot and typically used in bathrooms). Here is how I did it:
- Put on disposable nitrile gloves (a must!)
- Squirted the expanding foam on the styrofoam
- Squished the wet foam with the luan a few times to spread it around until it covered the whole surface of the styrofoam and the luan.
- Misted the wet expanding foam on both surfaces with water (expanding foam cures faster with water, like Gorilla Glue)
- Did the same thing on the other side with the FRP.
- Sandwiched the assembly between two 3/4 inch boards and clamped it for 24 hours.
The expanding foam oozed out around the edges and stuck to the clamping boards, so if I was doing this for real I would use masking tape and plastic wrap or parchment paper anywhere the foam could ooze. After it cured the excess foam was easy to pull off but left residue.
When I tried to pull the luan and FRP away from the styrofoam core there was zero give, and the styrofoam core was starting to break before I gave up. Some of the oozing expanding foam had gotten between the luan and the clamping board, and when I opened the clamping boards the expanding foam ripped off some of the outer surface of the luan, so it seems expanding foam is a better adhesive than what they use to make luan.
Based on this test I would not hesitate to use expanding foam as an adhesive to fix delamination in luan/EPS/luan/filon RV walls if I had a way to effectively clamp the area to keep the foam from expanding (if the foam freely expands it is relatively fragile). Although I did not test it with actual filon, the FRP is pretty slick and I figure anything that sticks to it will probably also stick to filon.
  • You have done a great test keep up the good work hopefully I won't need it but if I do ....lesson learned and will keep it on the back burner..
  • I've used both to glue pieces of Styrofoam together. For large pieces the expanda foam is quicker and eaiser to use. Smaller items your forever trying to keep the can opened up so you don't waste the remainder of the contents. Gorilla glue works fine for several square feet and is easier to cut with a hot wire. Use a piece of scrap whatever as a squeegee for spreading the Gorilla glue.
  • Think that much Gorilla Glue would be more expensive than the Great Stuff. Make sure you use the Window and Door (low expansion) foam, not the regular stuff in the red can. Think you might have some problems controlling the high expansion stuff.
  • Interesting. Thanks for posting. It's good to know information.
    Gorilla Glue really holds but, I think it would be a little more work spreading the glue as opposed to spraying the foam.
    The foam is messy, definitely wear gloves and old clothes.
  • I am wondering why not just use Gorilla glue? It is an expanding foam and it is much slower to expand. I am just thinking it might be easier to work with.
