Feb-03-2019 08:20 AM
Feb-07-2019 06:25 PM
Feb-07-2019 05:19 PM
Feb-07-2019 04:12 PM
Feb-07-2019 03:23 PM
Just There wrote:
I Have room in the main panel to configure the external A-C supply and the A-C from the inverter. Is this:
#1 Safe?
#2 Smart?
#3 Legal?
Also, can these supplies share the neutral bus bar?
Feb-07-2019 03:01 PM
Feb-05-2019 07:50 AM
chuckbear wrote:
One question. In installing the AIMS inverter with the built-in bypass, it shows bonding the inverter case to the RV frame. Is this really necessary? Chuck
Feb-05-2019 07:28 AM
Feb-04-2019 08:48 AM
wnjj wrote:x2
The EMS should be between whatever power source that could have trouble and whatever you want to protect. I don’t think a generator or inverter is likely to have issues..
Feb-03-2019 05:57 PM
Feb-03-2019 01:13 PM
Feb-03-2019 01:07 PM
Just There wrote:
Thank you! I now see where the Aims 2000 I’m looking at does indeed have a relay to break the bond with external AC. This goes along with what I’ve always heard: only bonded in one place at source of power. Gets kinda confusing with multiple sources. A follow up question, if I may:
Would the proper place for hard wired EMS surge protection be between the inverter and the Genset/shore power transfer switch?
Feb-03-2019 12:48 PM
Feb-03-2019 12:12 PM
Feb-03-2019 08:37 AM
