MrWizard
Jun 14, 2017Moderator
NEC is for the service drop panel to be grounded
Back when I did new home construction
We drove the ground rod next to the house right where the service drop was located
And run the ground wire from the service drop to the driven ground
The wire run from the warehouse to the pole should be (3) wires for 120v
If there are 3 wires get somebody to check the connections
If you have SWR problems, I would start checking equipment an antenna grounds
