ApexAZ
Sep 18, 2021Explorer
BFL13 wrote:
There is no wiring change needed as noted above.
The only thing is the one 24 they supply will be wasted money when you go for two 6s or two 27s later, so the saving for you should be for them to keep their single 24 and reduce your cost, and you supply your own batts, or they supply the batts you want and give you the cost of that one 24 off the price of the other batts.
Yep, I tried that. They wouldn't go for it.
Makes a lot of sense, right? But nope.
