CarnationSailor's avatar
Aug 02, 2016
Had a Problem with Alpha Ply Roof?
I have a problem with my Alpha Ply roof membrane separating from the underlayment and forming ripples and bubbles. It seems that at least the front 1/3 is loose.
I talked to a person in the RV roof business today, and he said there is a known issue with these roof systems that have been installed on Crossroads trailers in general and specifically the Rushmores. He also says there are "lots of postings" on the CR forum, but I can only find two.
I am trying to gather evidence of the extent of the problem before approaching Crossroads, so if you have had this problem with a Crossroads trailer, please respond.
Thanks
  • I don't have a Crossroads product, but I did have an Alpha Systems roof if you want to call it a roof. The membrane failed after 5 years and their 12 year warranty was going to cover $227.00. Rubber roofs are worthless in my mind and I will never own another one longer than it takes me to have it replaced by rvroof.com. And yes, I would have a brand new rubber roof sprayed over before it started leaking and caused damage.
    I don't work for rvroof.com, but am just a completely satisfied customer.
