Stewie_Griffin's avatar
Mar 12, 2023
Happijack bed lift trioubleshooting help needed
2018 Jayco Seismic 4212, got an issue with the Happijac bed lift system. Late last camping season, I raised and lowered the bench seats a few times throughout the day, but when I went to bring them down that night, nothing happened. I had to override the system and bring them down. Figured I'd deal with it later.
Well, I checked fuses, but none of them were blown. I checked the connections at the control board and switch, everything was good.
Well, we knew we were taking it to the dealer to get some other service work done, so I asked them to check it out. They said the switch and board were the issues. I ordered a new set and the parts came in the other day.
Now, the new upgraded switch is different. The old switch has two 10awg wires going to a small block mounted to the switch board and a phone cable/messenger wire. The new switch does not use those two 10awg wires, it has a ground spade (where the other switch had the 10ag block) and the phone cable. The old switch & board used the messenger cable to ground the switch, the new system doesn't use the phone line for grounding, apparently that was a trouble issue.
So, I hooked everything up, found a ground via an adjacent light switch...nothing.
I ran a new messenger cable, used a lawnmower battery ground post to ground the switch and confirmed I have 12 volts (13.3V actually) going into the new control board.
I hit the switch....nothing. I do not have power coming out of the control board at any point. When I have the DW toggle the switch, I read nothing at the control board outgoing pins.
Is it likely that I have another bad control board? What triggers the power to transfer out of the board? I assume the switch does it through the messenger wire. How can I test the control board?
Thanks for any suggestions you can give.
No RepliesBe the first to reply
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
