dougrainer
May 23, 2017Nomad
If you are positive the wire harness is GOOD, then the problem is the slide motor. The code tells you which slide motor. Doug
Having RV issues? Connect with others who have been in your shoes.24,192 PostsLatest Activity: Jan 26, 2025
