Golden_HVAC
Dec 27, 2015Explorer
Over the length of a 2' long cord, I don't think you could measure the voltage drop with a 12 amp load running through it.
Once I was parked in the pits at the Bowling Green Raceway, and had a #14 extension cord 50' long plugged into a 15 amp receptacle, with no fuses in sight. To that I plugged in a #12 25' cord, then a adapter to my 30 amp 25' extension cord, then my voltage booster, then the RV 25' long cord. From there, some 15' of #15 wire leads to the circuit breaker box, and another 25' leads to and from the inverter/charger with transfer switch.
Anyway while under load of the air conditioner on a 90F day, the voltage dropped to only 108 volts while being boosted by 12 volts! So I double boosted it back up to 115 volts! I can only guess how many amps where going through the #14 cord to the booster, then about 15 amps out of the booster. Voltage into the booster must have been around 92-95 volts?
Anyway the short small cord can work. The microwave will be fine. . .
Fred.
Fred.
Having RV issues? Connect with others who have been in your shoes.24,209 PostsLatest Activity: Feb 24, 2025
