hughesjm21's avatar
hughesjm21
Heat will not shut off. (Update)
2015 Tiffin 36LA Neither gas or heat pump will shut off when the thermostat switch is in the respective position no matter what the set point is. The gas does not run when in heat pump is source n...
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 17, 2025
