Old-Biscuit
Jul 10, 2016Explorer III
You have 12V DC to fridge.......thru stack thermal switch, thru OEM thermal switch and on circuit board at J4 and thru the 3A auto type blade fuse......BUT no 12V DC to upper panel (blue wire is test port for upper panel P1 connector) or fridge light (J2)
Circuit board.....bad
Replace with a Dinosaur Electronics Board...higher quality
