hippyguy03's avatar
hippyguy03
Help! Power Converter stopped charging batteries.
So, I just did something very stupid.. While reconnecting my RV batteries, I accidentally mixed up the positive and negative terminals and left it that way for about 5 minutes until I finally noticed and reconnected them correctly. Ever since then, whenever I'm plugged into shore power (or generator) all the outlets will work fine, and the DC powered items (lights, fan, etc) all work correctly, however the batteries no longer are charging. All the fuses and breakers seem good, and I don't see any damaged wires or anything.. and clues where I should start next?
Side note, the CD/Radio player has stopped working, and that fuse also looks fine, so I'm suspecting it was damaged with the mixup, or its not getting power for some reason. I can diagnose that another time, but the battery chargers are most important! I will post a picture of the unit and diagram - I believe the power converter is the 2nd breaker as labeled.
Picture 1
Picture 2
Picture 3
