kfp673
Jul 18, 2020Explorer II
Help with LED strips
Hello All,
I am installing some LED strips inside and outside the camper. inside was a breeze. Was easily able to find 12v power sources to tap into in 2 different locations. Outside however is not working and after 3 hours of trouble shooting I'm stumped. The strips have 12V power into a small controller and then a cable out to the LED with a 3 pin connector. The only difference inside vs outside is inside I spliced the power wire heading into the controller inside. Outside I had to splice the wires going from the controller to the LED strip. I spliced it into the factory 3 pin adaptor and got nothing.
Just to save time for replies, I will confirm a few things. I checked at least 10 times that all 3 wires were spliced correctly. I cut off my splices 3 times and redid them to make sure they were also correct. I used a multi meter and showed just under 13V going into the controller and just under 13v leaving the controller. I also used the multi meter to check the actual connector pins and again just under 13v. Had a second brand new strip. Tested that and still nothing. Tested another controller and nothing. Tested those same second strip and controller using the AC/DC power supply it came with and it works fine so I know they work.
So it seems like splicing the cable going out of the controller is somehow causing an issue, but I can't for the life of me figure out why. And because they only give you 3' of cable and the controller needs to stay dry, this is the only option.
Any thoughts???
Thanks
Any thoughts???
Thanks
