pianotuna
Oct 24, 2015Nomad III
Hi Mr Wizard,
No, I used a custom setting because of my "surplus acid" AGM's. I do have the temperature sensor in place, and I'm observing increasing charging voltages.
The Yamaha generator is essentially a 23 amp shore power device with 500 watts of overload capacity for ten seconds.
Even on a 15 amp shore power I would have had the fet overload happen. I had to dial back the input "throttle" to 13 amps to keep the charge rate down.
I believe I'll take your advice and email Magnum to see if they have an answer.
