gargoyle158's avatar
gargoyle158
Home based cell booster
I looked but haven't seen this issue discussed. Looking at adding a cell booster. They seemm to be a little pricey. Ran across a Weboost 4gHome, About 300.00. Only has a flat antenna so not good for use while driving. The RV models are 500 dollars and North. Here is the question, if I get the 4gHome and add an Omni antenna will that work while mobile? It has more power then FCC allows for mobile and the inverter would need to be on, but would it still work? I heard that the " home" units don't jump from tower to tower efficiently, that true?
Having RV issues? Connect with others who have been in your shoes.24,211 PostsLatest Activity: Mar 08, 2025
