Cummins12V98
Jul 08, 2019Explorer III
Crabbypatty wrote:
Ive had an oil change "pump", since owning a boat with a v6 down below. I use it on the 2000 as well as other small motors. Start it up, warm up the oil, turn off, then suck out the oil. Putting oil back in i use a funnel and look, add some, look add some.
I just used my Fumoto valve I installed on my 350 Boat engine last year (it was a mess). Slip hose on Fumoto run thru transom and into container and open the valve = GOLDEN!!!
