dreamco
Dec 17, 2012Explorer
Reddog1 wrote:
I would put the carb in a pot of very warm water for a few minutes. I think maybe the carb will expand more than the tube. Other than that, blow the carb out with air, reassemble it, and go back to it when you have more time. Be careful you do not blow the tube out and loose it.
Wayne
I was hoping to leave the eco throttle cable / wiring connected at the top of the carb as suggested in the first post. I've been trying to blow it out for hours..I don't think it's even budged. At this point the easier route may be to screw a very small ez-out screw extractor down the center hole and just order an new main nozzle / elusion tube. I just hope I'm able to remove any and all debris that falls in the carb as a result of using the screw extractor.
