Hopefully fixed the water heater problem
fyrflie
I think I have cured the water heater dilemma.
Installed new board and new igniter for the third time.
Found multiple screws that, by this point, had wallowed out the holes and were holding but only barely.
I replaced all of the screws and cleaned all of the contact points to assure a good ground. Then applied ant-oxidant for good measure.
First test and everything worked perfect.
Will be testing this weekend to further confirm the fix.
I meant to reply to my earlier thread but started a new one instead.
My apologies.
1 REPLY 1
Lwiddis
Wishing you good luck!
