enblethen
May 01, 2023Nomad
That means the switch or wiring is issue.
Remove the switch from the wall to gain access to terminals.
The both sets of end pins should have 12-volts DC. Switch should have opposite corners of switch jumper to reverse voltage polarity.
The center two pins should have 12-volts DC when switch is pushed.
see page five for basic wiring.manual
I didn't know Aloha still existed! Raised in Beaverton!
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 04, 2025
