theoldwizard1
Jan 28, 2018Explorer II
Regardless of what you choose, make sure it has the correct outlet for your cord or that you have an adapter. Dual 2000W generators will not have the correct outlet and trying to pull 30A through only 1 receptacle (they are rated for 15a) is not a good idea.
The Honda 3000W generator has a 30A outlet, but it is not compatible with a 30A RV cord. You would need an adapter.
