Rmack1's avatar
Rmack1
how big of an inverter for Direct TV
As I've mentioned on other threads, I'm looking to install an inverter to run my Direct TV components from my batteries.
I asked around, called the companies, and determined that;
My TV uses about 33 watts
The 'Genie' receiver about 18 watts
The Winegard Trav'ler dish uses 120
And the SWM system that I need to run my Genie also uses 120
This last part was determined by a Winegard tech who said that voltage times amps gives you wattage. Is this correct?
He also confirmed my suspicion that the dish uses less power after it's finished using it's electrical motors to align itself with the satellites, but he didn't know what the difference was.
So, I could get away with a 300 watt inverter, if they make them that size.
Question; is there any advantage to inverter overkill? Like, would a 400 watt inverter have any advantages over a 300? Would it run cooler, more efficient, anything like that?
Thanks
Having RV issues? Connect with others who have been in your shoes.24,192 PostsLatest Activity: Jan 26, 2025
