Bionic_Man's avatar
Bionic_Man
How cold should the air conditioning get the RV?
We've had the trailer since new. It is about 32'. Air conditioning is original. It is the 15k model (Dometic?). I don't remember having problems in the past, but this year, the AC doesn't keep up as well as I would like.
Trailer was in full sun. I had all the blinds down. Not running any appliances, the AC would keep the inside of the trailer about 10* lower than the outside temp. So, at 95* outside, it was about 85* inside.
I have always heard that the air coming out the vents should be about 20* cooler than ambient indoor temp. I didn't check that, but we couldn't get anywhere near 20* cooler than outside temps.
Is this to be expected, and I just have a bad memory of how it worked in prior years? Is there a way to add coolant to the unit? Would replacing the unit make a significant difference? If it is up to me, we are keeping the trailer, so I am ok spending some $.
