neu
May 06, 2023Explorer
Boomerweps wrote:neu wrote:BB_TX wrote:
You don't say what you are towing with, or what you are towing. My question: is the trailer tongue weight too much for your tow vehicle making the tow vehicle rear sag too much. You pictures don't show enough to tell.
The car is sagging, but not too much.
I have an Audi Q5, and I understand that it is not the ideal car for towing a trailer, but the tongue weight at the time of the question was within the acceptable limits: 405 pounds out of a maximum of 440 pounds.
I do not plan to exceed the upper limit. In the worst case, I plan to carry the propane tank in the car's trunk or put something heavy behind the rear axle. I have not yet weighed the entire trailer to accurately answer this question.
20# propane tank weighs 17# empty, plus 16# normal propane fill on exchanges, nets you another 33# on your tongue weight for a total of 438#. So you can tow with your propane tank installed, securely mounted. For longer camping, a 30# tank only adds 2 more pounds empty, plus 10 more pounds propane. You’d need to pull a few items from the trailer front storage to do so to be in specs. You might want to consider a LiFePo4 replacement battery. Normal batteries weight about 60-65#, LiFePo4 weighs 25# for a 100AH unit.
Very good point, you are completely right! Thank you!
